ENAW-6101BENAW-AlMg4.5MN0.7(B)ENAW-AlMg4.5Mn0.9ENAW-AlMg4ENAW-AlMg4Mn0.4ENAW-AlMg4.5MnZrENAW-AlMg4.5MnZr(A)ENAW-EAlMnSiENAW-EAlMgSi
2024-04-18 20/kg5182525151545454565257545N015N026003600高等6060606360826151618162626951700370207049A7050707270757N017N8280218079AlZn4Mg1.5
2024-04-18 20/kgAlSi12.2Al-Si12Cu.1Al-Si12Cu.2Al-Mg3.1Al-Mg3.2Al-Mg5Si1.1Al-Mg5Si1.2Al-Mg6.1Al-Mg6.2Al-Mg10.1Al-Zn5Mg.1Al-Zn5Mg.2A995A99A98A97A95A8
2024-04-18 22/kgENAW-8211ENAW-8014ENAW-8112ENAW-8015ENAW-8016ENAW-8018ENAW-8079ENAW-8021BENAW-8090ENAW-AlFe1.5MnENAW-AlFe1Mn0.8ENAW-AlFeSi(B
2024-04-18 20/kgENAW-AlMg0.7Si(B)ENAW-6081ENAW-6181ENAW-6082ENAW-7003ENAW-6082AENAW-7005ENAW-7108ENAW-7009ENAW-7010ENAW-7012ENAW-7015ENAW-A
2024-04-18 20/kgENAW-AlMn0.6(A)ENAW-AlMn1Cu0.3ENAW-4004ENAW-4104ENAW-4007ENAW-4015ENAW-4016ENAW-4017ENAW-4018ENAW-4032ENAW-4043AENAW-4343EN
2024-04-18 20/kg2024-T32024-T42024-T3512024-T361Alcad2014-T361Alcad2014-T81Alcad2014-T851Alcad2014-T8612025-T6Alcad3004-0Alcad3004-H32Alcad3004-H34Alcad
2024-04-18 20/kg铝合金:A5056WA5083BDA5083WA6061BDA6061WA7075BDA1085PA1080PA1070PA1050PA1100PA1200PA1N00PA1N30PA2014PA2017PA2219PA2024PA3003PA3203PA
2024-04-18 20/kg3522AlSi12CuFe3522AlSi8Cu3Fe3522AlSi12FeR164AlSi12CuR164AlSi12FeR2147AlSi123522AlSi5R164AlSi5R164AlSi5Fe3522AlMg3R164AlMg3R2147AlMg33522
2024-04-18 20/kg德国铝合金:E-AlHAlRMg0.5AlRMg1Al99.9Mg0.5Al99.9Mg1Al99.85Mg0.5Al99.85Mg1Al99.9MgSiAl99.8ZnMgAlFeSiAlMn0.6AlMnCuAlMN0.5Mg0.5AlMn1Mg0.5AlMn1M
2024-04-18 20/kg12351350137011991A99Al99.8E-Al99.7Al99.7E-Al99.511451A451A35Al99.5Al99.00Al99.8(A)Al99.851A50LG5LG4LG3LG2LG1L1L2L3LB2L4L4
2024-04-18 20/kgAlMg2AlMg2.5AlMg3.5AlMg3.5(A)AlMg3MnAlMg3Mn(A)AlMg3AlMg5CrAlMg5Mn1AlMg4.5Mn0.7AlMg4.5Mn0.7(A)AlMg4E-AlMgSiE-AlMgSi(A)AlSiMgAlSiMg(A)
2024-04-18 20/kgZLD106ZLD107ZLD108ZLD109ZLD110ZLD203ZLD301ENAC-AlSi7MgENAC-AlSi12ENAC-AlSi5Cu3ENAC-AlSi10MgENAC-AlSi5Cu1MgENAC-AlSi6Cu4ENAC-AlSi
2024-04-18 20/kg403240434043A43434643404440454145414高等404640474047A414740485005500高等5205530555055605500650105110521053105016501750185019
2024-04-18 20/kgAlmag35220712.0712.2712.2713.0713.1771.0771.2772.0772.2850.0850.1851.0851.1852.0852.1853.0853.2XC750XC850.0B750B850.1B850.0A
2024-04-18 20/kg铝合金:P0202AP0303AP0303BP0404AP0404BP040高等P0406AP0506AP0506BP0507AP0507BP0610AP0610BP0610CP101高等P1015BP1015CP1015DP1020AP1020BP102
2024-04-18 20/kgAlSi7Mg0.6ENAB-AlSi10Mg(A)ENAB-AlSi10Mg(B)ENAB-AlSi10Mg(Cu)ENAB-AlSi9MgENAB-AlSi10Mg(Fe)ENAB-AlSi11ENAB-AlSi12(B)ENAB-AlSi11ENAB-A
2024-04-18 20/kgENAW-5554ENAW-5654ENAW-5754ENAW-5654AENAW-5056AENAW-5356ENAW-AlMg2.5ENAW-AlMg2.5(B)ENAW-AlMg2.5(A)ENAW-AlMg3.5(A)ENAW-AlMg3.5Mn
2024-04-18 20/kg铝合金:1050A10501070108010851100120012301N001N301N901N9920112014A20142017A201820242025203021172218221926182N013003300430053
2024-04-18 25/kgAC8C.2AC9A.1AC9A.2AC9B.1AC9B.2A-Cu4Ti.1AlCu4Ti.2Al-Si5.1Al-Si5.2Al-Si5Mg.1Al-SiMg.2Al-Si5Cu3.1Al-Si5Cu3.2Al-Si6Cu4.1Al-Si6Cu4.2Al-Si1
2024-04-18 20/kg20052006200720082009201020112011A2111201220142014A20172017A2018221826182618A2219231924192519202120242024A212422242224A23
2024-04-18 20/kg390.2A390.0A390.1B390.0B390.1392.0392.1393.0393.1393.2408.2409.2Vanasil392A390390384B384.1B384.0411.2413.0413.2A413.0A413.1
2024-04-18 20/kglMg2AlMg2.5AlMg3.5AlMg3.5(A)AlMg3MnAlMg3Mn(A)AlMg3AlMg5CrAlMg5Mn1AlMg4.5Mn0.7AlMg4.5Mn0.7(A)AlMg4E-AlMgSiE-AlMgSi(A)AlSiMgAlSiMg(A)A
2024-04-18 15/kg4047A50193103221922172214AlCu2MgNiAlSi52A162B162A062A252A502B502A704A134A174047A501950421N991N90EAl99.5Al99.35123513501370
2024-04-18 20/kg铝合金:A5A8A45A4A-U4SGA-U4G1A-M1A-G0.6A-G4MCA-G3MA-Z5GA-Z5GUA-U8SA-U8SZA-S5U3A-S5UZA-S7GA-S7U3GA-S9GA-S9GUA-S10GA-S12UA-S13A-U4
2024-04-18 15/kgR164AlSi6Cu43522AlSi5Cu1MgR164AlSi5Cu3522AlSi7MgR214AlSi7Mg3522AlSi10MgR164AlSi10MgR2147AlSi10Mg3522AlSi8Cu3FeR164AlSi8Cu3Fe3522AlSi12CuF
2024-04-18 20/kg铝合金:SIASIBFIBNS8NF8HF9HF12NS3NS4NF4NT4NS5NF5HS15HC15HF15HF16HS30HF30E1EE01EE1BE1CNE4NE5NE8HE9HE15HE20HE30T1BT1CNT4N
2024-04-18 140000/kg铝合金:SIASIBFIBNS8NF8HF9HF12NS3NS4NF4NT4NS5NF5HS15HC15HF15HF16HS30HF30E1EE01EE1BE1CNE4NE5NE8HE9HE15HE20HE30T1BT1CNT4N
2024-04-18 20/kgAlMg5MnE-AlMgSiE-AlMgSi0.5AlMgSi0.5AlMgSi0.7AlMgSi1AlMgSiPbAlMgSiCuAlCuBiPbAlCuMgPbAlCu2.5Mg0.5AlCuMg1AlCuMg2AlCuSiMnAlZn1AlZn4.5Mg1
2024-04-18 20/kgLC19183-1LB733LC525210LC12L6LT98ZLD109ZLD204AZLD20高等ZAlCU5MnCdVDAZL109YRL680118011A80798006ENAW-8011AX7064AlZn1800180048005
2024-04-18 20/kgA750A850.1750B771.2Precedent71BB771.0Precedent71A613(Tenzaloy)D712.2D61240ED712.0D61240EZLD101ZLD102ZLD103ZLD104ZLD105ZLD106ZLD1
2024-04-18 20/kg62016101A6201A640160026003610360046005600高等6005B6105620560066106620663066007600860096010611061116110A6012601361136014601
2024-04-18 20/kgAC7A(含镁3.5%~5%)合金的耐蚀性,特别是对海水的耐蚀性好,容易进行阳较氧化而得到美观的薄膜。在铝镁系合金中,它是伸长率非常大、切削性也好的合金。但熔化、铸造比较困难。AC7A铝合金耐腐蚀、韧性、阳较化性能好,铸造性能差,用于架线、配件船舶零件、把手、雕刻坯料、办公器具及飞机电器安装用品
2024-04-18 22/kg合金代号:ZL101标准:GB/T1173-1995特性及适用范围:可热处理强化,具有自然时效能力,强度较高,塑性较好。该合金的铸造性能优良,流动性好、线收缩小,热裂倾向低、气密性高,但稍有产生气孔和缩孔倾向。合金的耐蚀性高,焊接性好,切削加工性一般。硅Si:6.5~7.5镁
2024-04-18 20/kg
